2XU where to buy?
Re: 2XU where to buy?
jaskin;901935 said:
ok... quick question... do you guys wear undies with the tights?
i use to wear but now i dun, u should feel better.
Anyone here tried "SiS GO Isotonic GEL" ?
DrK;901903 said:
Compression tight tops may cause lesser abrasion to your nipples compared to free singlets during SCB runs. Just apply vaseline to your nipples before run.
SCB runs start at 530pm (assuming yours is the 42km) so that timeslot should be cooling enough. By 8pm, it will be somehow hot but you will probably be too shaacked to notice if your compression top makes a difference. But it should make a difference because you will be very sweaty and the compression top sticks to your skin and avoid fluffing around. It feels cool too if a breeze comes by.
Personally I prefer Zoot for running and 2XU wetsuit for triathlons because they feel better in water. But both brands do not offer enough support for the groin pad causing uncomfy balls during bike leg.
I don't wear compression top for running as i feel uncomfortable. I usually wear it the day after my weight training for muscle recovery. To avoid nipple chafing, i usually wear loose loose T + body butter.
I will wear lycra undies as my balls feel insecure.
For marathons, I did. Somehow I feel more supported when running. But when you perspire so much and your undies is so wet, it is a sick feeling. So up to you.
For tri, I don't. I don't like to swim with undies.
yo went through my dropbox. Found the contact. Ken Phua 9100-5302 He quoted me around 20% off all 2XU products. I think he also carried New Balance.
denealjojesf001;903289 said:
Hello friends.
In my opinion you should try wiggle.co.uk. Here you found latest an good 2xu. 2XU engineer products with the single minded goal of best equipping the athlete, so they feel more prepared, more lethal, more capable than anyone. 2004 Winnebago AC Compressor With 2XU technology a piece of the finely balanced equation is in place to multiply human performance.
Nice to meet you.
Thanks.
got mine from wiggle too..
2xu have discount if u Newton challenge runner. Only at novena sq
pg88comim
