ABS Indicator
Explorer
After you have stepped on the brakes hard, and the ABS kicks in (felt through the pedal vibration), does the ABS indicator on the dashboard light up? I just changed my brake discs+pads, and I don't see the ABS light up while braking. I can't remember if it did in the past either. Thanks
Re: ABS Indicator
I was told it won't light up.
Re: ABS Indicator
Okay -- edit: if traction control (ASC/DSC) kicks in, then the triangle symbol should light up. Not sure about ABS though.
Re: ABS Indicator
ABS does not light up when activated, only feel the pulsation.
emiffy is right, the traction control triangle does light up when it kicks in
Re: ABS Indicator
when the abs light comes on, its not a good sign...... my did, and i had to replace the ABS control module.....
fun886cc
