MapleLeaf;284969 said:I had this once, and it ended up as only a little short on brake fluid. So check your brake fluid first - cheapest option
VenomX2;284921 said:could be a faulty ABS module.
RTCS;285293 said:Oh, sure hope is this shortage of brake fluid. I will check it out tomorrow morning. Thanks.
ABS module refers to the electrical circuit and not the main pump right? May I know where is the module located, feel like taking it out to take a look. Is it anywhere near the main pump in the bonnet or behind the glove(drawer) or below the steering wheel? Thanks.
kopibengz;285380 said:...the abs signal gone......
duno, wats happen....??? some feedbk my batt is weak...
RTCS;285489 said:checked the brake fluid and it is sufficient.
found the abs module which is behind the glove compartment. removed and stripped it. removed the pcb and did some cleaning with wd40 and toothbrush and followed by visual inspection and seems alright. fixed back everything and had high expectation but abs warning light still comes up. wasted 2 1/2 hr.
most likely is the abs pump ko liao, i am hestitating to strip the pump.
sszone;285868 said:can try opening up your hood, look for the right side...there's this box with all those little chips in it.....look on the cover for the one controlling the ABS, take the chip out and try putting in another one with same color and voltage (there should be some spares on the underside of the cover)
SpeedyGonzales;287378 said:if your car is no longer under pml warranty, i recommend signing up with Warrantysg | Kar Engineering at least you save $$$ when the ecu or abs breaks down.
