AC Schnitzer Kit & M Pedal set
Re: AC Schnitzer Kit & M Pedal set
newbie shawn;878237 said:
Can share how to diy the pedals? Thks in advance.
For Forrestgum and me, it was mostly trial and error but these are the basic steps.
Accelerator
1. Remove the accelerator module and focus on aligning the pedal from the top.
2. Use tape to make sure the fitment is tight.
3. Use a 3mm bit to drill through the four holes.
4. Nuts and bolts are next (3 will be enough, 2 on top, 1 at the bottom, you will see why)
Deadrest
5. Align it to your fancy and put your weight on it to prevent movement.
6. Screw in directly (with power drill)
Brakes
7. Remove the rubber cover
8. Stick 2 strips of masking tape, one each on the top and bottom of the pedal
9. Align your aluminium brake over the masking tape and mark out the hole to be drilled.
10. Drill through, slowly and putting only a bit of pressure, with a 3mm metal bit
11. Apply 3M heavy duty tape to the pedal (optional)
12. you know the rest
Come for the GTG on Fri, many of us can talk you through it.
bro leslie.....i also jumped ship liao.
but went for e87 instead of your f20.
tks bro.
i cant stand the clunking in my black pearl anymore esp after long drive.
feels good to be back on a NA actually....hahahahaha.....
btw...got pedal set ah? you all GB?
oyster69;880699 said:
tks bro.
Haha! NA...... Really obi-good :LOL:
Woohoo we're reunited again! The guys/gals here are great, don't be shy to poison them!
So good to be with you guys again and les.....you and Bubba are the poison kings now!!! :p
Ben, I getting old...can't handle the speed like you guys and the turbo boosts....linear is good for me. ;)
Nonsense Oyster, you talk more sense than most people I know and you surely know what you're doing. It's time for me to return the favour and poison you! What are you looking at?
Bro,
I need a pedal set.
But what options are there...share with me pls to shorten my learning cycle. :thumbup:
Any that doesn't need to drill?:rolleyes:
View attachment 41003I just installed mine (Thanks to Leslie).
Finally! Looks great!
But jia lat the very good cashier at the workshop almost convinced me to buy the ECUTECH tuning box. Must resist!!
rogtoto4dgg
