ADVAN RACING RS for BMW
Re: ADVAN RACING RS for BMW
3ci;418049 said:
:yikess: serious ? .. no other option ?? ..
You right bro, just confirm with leong seng .. If order one pcs have to wait 1 / 2 months.. :(
They looked more scratched then dented.
But its better to head down to a rim shop and get a professional answer from them.
when i was buying my rims, leong seng told me that they can fix scratches on the gunmetal advan rs but not the silver ones...
oh shiit :laughlik:
I think that the reason would be that they do not have the paint range to match the colour of the rims. Furthermore, some silver rims are really bright/reflective silver and conventional paints do not produce that kinda of luster.
Once u verified that it is not dented, u can bring to a paint shop to get it puttied over and sprayed.
hi. for E90 rear 18x9.5, are u saying BOTH ET +35 and +25 won't rub? Thx for ur help.
TripleM;403998 said:
no need for spacers, be it staggered or non staggered.
wont look that superflushed but definitely no rubbing
3ci;418225 said:
Are this can repair ?
My Advan Racing RS got scraped against the curb too, when swerving to avoid a jaywalker.
Tristan at Hurry Tyre fixed it for me in 30 minutes at a surprisingly reasonable rate. Nice job, with matching paint. Impossible to restore to 100% original condition of course. You note the traces when up close. But can't notice from further away. You could ask Tristan.
All the best with your repair
If I may chip in:
18 x 9.5 +35 is specifically made by Advan for E90 rear wheels.
With 255/35 Tyres and springs lowered by 30 mm, there is no rubbing whatsoever.
Wheel is flush with the inside of the fender with a few mm of clearance.
Anyone used +25 offset for E90? Sounds risky.
Bmw38;403905 said:
e90 rear wheel put spacer is safe and look good
mind telling me what rims are on the car below ur sig? (in the pic below, the black rims with polished lip?)
thanks will try it.. .. mine have two wheel need to repair.. :(
+25 on 9.5 can fit, v flushed but u need to roll your fender and run slighlty a bit more negative camber, maybe ard -1.5deg then u r fine.
Newbie here just a question in my mind for the FL E90 still going for +25 offset for rear?
Yokohama Advan RS so jippun for BMW, why is everyone going along like annual wildebeast migration. Ang Mo chia wear asian shoe not so nice le, Kenn say one. kekekekeke
Ang Mor chias fit well into Asian shoes, v tight they say..Toto says one.
I will like to check:
1) With the 18" Advan RS 8.5(F), 9.5(R) c/w tyre profile of 30mm/35mm on a FL E90 with M-Sport suspension, how many finger gap will there be?
2) For this Advan RS 18" rim, what is the maximum rotor size can it accomodate as i'll like to change to 6pot/4pot BBK.
Thanks
1. reckon bout 2 fingers there bout max....surely not ugly
2. to be safe 355mm
pg88comim
