Advice on Brake Replacement / Upgrades
Akingston
New Member
Re: Advice on Brake Replacement / Upgrades
If your car sees a lot of rain, don't bother with drilled disks, as they can crack between the holes.
I have DBA slotted disks, pagid semi race pads. and decent brake fluid. They pull up so well your eyes will pop!! hehe
just changed to x-drilled because of the looks... dont think the braking performance will be enhanced till i can feel it...
i went this way, checked pml original parts (disc+pads)... then using this budget, i worked out being able to get brembos + pagids (sport) plus some savings... certainly a good and economical upgrade from stock...
Did you guys realise that the original posting was almost 4 years ago..........?
Whats the cost of the disc+pads in PML? I tried enquiring on the pricing of parts in PM a few times. I couldn't get through most of the time but when i did, the enquires assistant on the line wasn't sure, :angry:
Called them up before and they quoted S$200-S$2000.
Utterly brilliant! :)
A pair of stock pads should set u back not more than $100 from engsoon. Rotors not more than $500, but a piece or a pair i'm not sure... this should give u a gauge.:)
Icic. Thanks for the info!
I got mine replaced at some private service workshop I got my pads at 210 per set and 390 for a pair of discs not sure if i was a good deal.
just changed a pair of front rotors for 250 and pads for 110 excluding labour. j4c and bvo is quite close in pricing.
Sounds about right... :)
Reckon labour should set you back another 40-80.
thanks for the tip...as my rear pads are wearing out fast..6 months warranty to go with PML. so kindda caught between where to get it fixed.
bong88nyc
