Model?? Beside the vent got a button blue n red can turn de. If red also wil blow out hot hair. Turn it 2 blue.jojosnr;997520 said:Anyone experienced this ? Passenger side ok, driver side blowing hot air sometimes.
Please share if you have similar experiences. What could be the problem and possible remedy.
Thanks.
Ah yang;997562 said:Model?? Beside the vent got a button blue n red can turn de. If red also wil blow out hot hair. Turn it 2 blue.
mercur1al;997596 said:I believe ur cooling coil is leaking.
First symptom of a leaking cooling coil is the 2 central vents at dashboard, one will be cold and one will be blowing hot air.... according to my mechanic.
Otherwise, try topping up ur aircon gas and observe first.
jojosnr;999909 said:Thanks to all for your advice.
Sent it in two days ago. Shop topped up gas and is now good again. Heng.. that is was not something serious.
Deepster;1022584 said:Bro, I had the similar problem. It's not the compressor.. Hopefully. But topping up gas is just the quick fix solution. Monitor again how long it takes to get out. It's definitely the cooling coil. Eventually have to change if it carries on. Am going to do mine after buying the parts and doing at my workshop.
jojosnr;1022692 said:You may be right. Where are you doing it ?
Deepster;1023886 said:I'll be doing mine probably next week at msia. Pm if you need any details.
Zincman;1023955 said:my friend change his coil at one of our site sponsor for 1100,TS u may want to visit tomika at alexandra village.heard the reviews quite good
