air con
ghost
hi dude
before driving off i started my engine for 10min with the air con on and spotted water underneath. is it normal?
pls advice
thank you
Re: air con
dude,
is it your first car?
does other cars you drive before have the same sign?
and you might want to check if its really water discharged from your aircon
maybe its atf or engine oil or coolant ????
Re: air con
its my second BM. as this is the 1st time i started the car w/o moving for 10min with the Air Con running and the 1st time looking underneath with water.
now I'm puzzled!!!
Re: air con
ghost;886370 said:
hi dude
pls advice
thank you
cold or hot???
cheeeeeeeeeeeeeeeeeeers
Re: air con
TS already went home last night.
Kidding.
Btw, If it's not Aircon water and is some other liquid, then probably that liquid tank has already emptied and TS would have got it repaired.
Re: air con
Hi, help. i realise that my aircon compressor clutch is alway engaged even when i turn the ac off. is it alright? mine is 2007 320i.
w9betgroup
