Aircon still on while engine is off!!
Send back to AD?
Alan
Sent from my iPad using Tapatalk HD
Re: Aircon still on while engine is off!!
Luckily now not 7th month, otherwise it must be Guni.
Sorry OT.
First time I heard of this. You should send back to PML....or some other workshop if your car is out of warranty. But please make sure you can show the same malfunction again. Otherwise, when they surround you, you off engine, then aircon also switch off like no problem at all....then everybody will stare at you and say "what?"
Pianoman;797116 said:
Someone please help? My air con still on when I shut off my engine. What is happening? :helpp!:
if this is true... you can still start engine the next morning?
battery will be flat by then
Your aircon can run without engine running is a good sign. All car manufacturers would want to learn from you .
Don't worry my friend. I'm sure there's
A solution . Perhaps your engine so quiet an u thought its already off
I thought there was a setting which allows us to on the air-con at a specific time? Maybe there is also a similar feature which delay the air-con switching off?
Knn 2 pages and all talking cock...
It's the Final Stage Resistor failing..or BMW calls it Blower Motor Resistor. Just get it changed, not very expensive
by88zme
