any rim repair open on sunday??
hellboyII
hi all<
just kena curb rash from some stupid dark parking place>
any 1 know which shop got open on sunday for repairing curb rash?? rim rub against curb??
got must be good skill expensive a bit is ok. and noramlly take how long??
apperciate any advised asap.
Re: any rim repair open on sunday??
hellboyII;405359 said:
hi all<
You will probably see differences in colour between the damaged portion and the rest of the rim even after touch up.
Best option is to spray entire rim.
look for raymond at RAY's at Kaki Bukit. Closed at 6pm
hi bro,
ok noted your advised.
hi bro,
ok noted. i bought my rims from them. they got open on sun ah....
Whilst your 'spray the entire rim' is the best (most costly and time consuming) option, it is not true that the difference in color is evident, unless it is done badly.
Anyway, the last time Ray 'did' my rims for me, he didn't touch it up, he filed it down. This makes it very noticeable.
Unless the paint is exactly the same, under certain angle and lighting, bound to have differences.
i have made a appt this coming sat with 1 shop saw their work i think should be ok. will post a before and after pic.
hi silky,
i share the same thought too...but bobian... this is the best i can do now. hope fully it turn out ok...
i had the same issue as u. did some touch up job, looks ok initially, after a few weeks, colour started changing. ended up spraying the entire rim. now swee liao.
you initially wanted it done on Sunday, its now Monday. Might as well do the entire thing?
hi bro,
hmmmm u know spray entire rim cost how much? i scraed the colour they unable to blend. mine is dark gunmetal advan connsseiur 151c 19inch
I know PML charges $160. You shld be looking at anything below this at shops outside. They should be able to get the colour close. Go for reputable shops.
Suggest you ask the guy how close and to what level of finish he can get it to be before proceeding.
hmmm ok noted.
If the rim has a small hole causing air to leak, is it advisable to do a repair on that ?
Thanks....
Thanks....
hi silver,
if small hole and you normally dont drive fast and furious i think its ok to repair/mend. but this is just my humble thought only. other bro might have better advised. but how come your rim got small hole which cause the air to leak?? which part of the rim got hole??
Thanks....
The tyres are your only contact with the road. For safety, I would advise to change the rim.
The 1 hole is size of a ballpoint ink mark and is located at the tail end of the 5 spoke nearest the hub. This is likely to be caused by a pot hole which I hit a day earlier. Though I would have thought a hairline crack is more likely than 1 tiny hole.
Since it was leaking at the rate of 1bar per night, I changed the rims the next day though a tyre shop told me it can be welded back. Another one said, they use silicon to mend which i thought was unsafe.
Thanks all.
hellboyII;406073 said:
hi silver,
hi all,
attached pic of rim repair left is before right is after. good service and the blending of the colour is good. cost me 50bucks
Hi there! Which shop did you get this repair done at?
hi mars
at amk autopoint 3rd floor, u need the full name pm me. as i think not allowed to post shop name here.
