Average water temp reading in 335?
tortoise
Plugged in a Scan Gauge just now and was kinda surprised to see 109 degrees on the water temp, anyone has similar experiences?
Kinda high for a F30 335 that has not been touched yet (as in mods)
Re: Average water temp reading in 335?
Jason,
Temp is there about for stock setup.. Need not worry..
My 4cyc E90 is at 35 ~ 50 degree before morning start up. When reach work place is at 102 ~ 105 degree..
(I use the cluster built in gauge to view)
Cheers ~~ :)
Normal range for water temp.
Oil temp normal up to 120 degrees.
If reach 100 degrees, means water becomes water vapour?
Correct at atmospheric pressure but the coolant system in a car is pressurised so the boiling point of the coolant is higher than 100.
My water temp used to hover at abt 105 deg while engine temp hovers at 110-115 Deg, constantly for 'whichever part' of the day I drive.
After switching to Castol engine oil, I notice '2 patterns' - My water and engine temp now hovers at 93-96 Deg and 103-109 respectively during evening driving while during the morning plus afternoon, water and engine temp is 103-105 Deg and 110-115 Deg respectively. The latter also applies to frequent petal-to-metal driving for 30mins.
I read e water/engine temp from my steering wheel. My ride is not 335 but is N54 engine.
If u like to bring the water temp lower, try a thicker and bigger radiator, will drop by approximately 20-30 deg over current :p
Thanks...........
Hey Baby1M,
Mind to share more in-depth on this?? Ive being wanting to bring down the water temp lower.
Thanks in advance.. :)
** U may PM me if too :eek:
Cheers ~~~ :)
tomace;894900 said:
Hey Baby1M,
Cheers ~~~ :)
Do more read up on this. Based on my understanding, there is certain default water temp for BMW. I asked before about this but adviced not to do so.
tomace;894900 said:
Hey Baby1M,
Cheers ~~~ :)
What in-depth you would like to know? Consider radiator change (or in shopping list) only if u r going to do many performance upgrades to boost up her power/torque... cooling is important when one upz e power/torque alot.
I did not change the OEM radiator in my ride as I trust what BMW had specified as there is no requirement to improve the cooling issue for now.
I posted e suggestion because of experience from previous ride where e ride's water temp hovers at 90+ Deg and upto 120+ Deg under normal and hard driving respectively. After changing to the biggest possible radiator that can fit, the water temp hovers at 72 Deg (normal) and upto 110+ Deg (hard driving or traffic jam)... all other parts unchanged nor type of coolant.
Been reading up / asking around since day one :eek: Same answer as yurs.. stay as it is unless u touch engine.
My ride since day one, auxiliary fan kicks in MAX after 15~20mins of jam.. so thot of bringing it slightly lower or keep it more stable..
Anyway, im on Q for replacement ride to check it out. (CSA also find it not usual but no fault when dyno) :(
Thanks ~~ :)
IC ~~ Noted with thanks.. so far have for 335i & none or not trustworthly for 320i :(
Cheers ~~ :)
Tortise, my scangauge reads 91 degrees.
Maybe because the driver is cool. Sart.
pg88comim
