hi guys,
wow! i can finally post in the main forums.
i took delivery of a new 320i professional (my first beemer) at the tail end of dec 2008 and am loving every minute of owning it. i have a couple of questions relating to the stock audio system which i hope you'll be able to help with.
1. the stock headunit - i can connect my ipod and it can play my music but the track titles are all garbled and i can't access playlists and other ipod functionalities. and since the ipod goes into charging mode when i connect it to the 320 via usb, i can't access playlists on the ipod either. so, the ipod acts like a hdd. i've read the forums here and gather that i'd need either a special cable from bmw or some sort of interface in a box. i also understand that there is some sort of "reprogramming" that is required. i'm a little lost. apprecaite if someone could help enlighten.
2. the forumers here have been talking about logic 7, denison, dice, etc. what are these? i've done a google search but couldn't gather much. *sigh*
3. i would also like to know if the stock headunit has a mute wire to connect a car kit. this means that when a call comes through, the radio / cd mutes automatically.
4. has anyone replaced the stock headunit in a 2008 320i? i was wondering how it fits as the stock headunit's enclosure looks a lot bigger than the standard single din. is there a frame of sorts? does anyone have pictures to share?
5. will there be an issue if i replaced the speakers and add amps to the stock headunit? will i need to bring the car back to pml for programming or anything complicated like that?
my apologies for the numerous questions and thanks in advance for any help rendered.
cheers,
prem
cheers,
prem
