Brake pedal vibrate and DSC warning light
Re: Brake pedal vibrate and DSC warning light
babe said:
worst come to worst, I sacrify a bit and use some "mei ren ji" loh...whaahahahaaa...:lol2:
Haha ok that's worth a try cos I don't think many others have tried (or have the means to try). Or maybe some tried but failed, then kept quiet, keke.. All the best to you!
there seems to be an electronic problem here. a simple plug into the Modic should identify the problem and the program will suggest a solution to rectify it. Even the coffee shop auntie will be able to help you with this one; dont think you will need to bang lots of table or find the bestest CSA to do the job this time. even if the DSC module fails, the ECU will settle down into a safe mode so you can continue driving.
"mei ren ji" will not work on alexanda pea brain Andrew (CSA).. he will tell u all women are the same... like what he told me all BMW got same problem.
Got the car back and they didn't find any fault to it.. They said the problem is due to the DSC trying to realign the car and it might be a little sensitive :)
So how's the car now?
You went to Kg Arang or Alexandra?
Went to Alexandra...cos nearer.. *i did try to avoid Andrew* :yummie:
the CSA and the technician very friendly.. help me to touchup some scratches at the front bumper and replace one of the door rubber..
Car is ok so far.. they asked me to monitor and bring it back to them if still got problem:)
So you got your car back in a day's time ya?
Car got problem again yesterday.. brought it in this morning and this time they have found out its the DSC sensor problem.. FINALLY...:)
Hmm..it seems that DSC is a bloody common problem. I know of some other guys apart from myself that have had problem with the DSC sensors. :furious:
You better touch wood. Quick touch your head now.
Your head looks a better bet. Infact, even a tree pales in comparison to your head.
hb88covn
