Brakes meant for E36 M3 - can fit into plain ol' crappy non-M E36?
Re: Brakes meant for E36 M3 - can fit into plain ol' crappy non-M E36?
needs some modifications to fit. not plug n play afaik. not sure bout the costs
Hm....you do mean the E36 M brakes on the non-M E36 right? I think the M brakes with the M carriers do fit on the non-M spindles, at least they did when my mech test fitted. It's getting the right set of rotors tt's gonna be a bit of a challenge.
Not sure if all the above is correct, but tt's what I was told at the workshop, I chose to fore-go the M calipers for smth else, so not sure if it really works. But if you're interested I've got M calipers with carriers to let, spindles/kingpin not included.
cheers.
Very simple answer
1. You need the M3 Kingpin/Knuckle to use M3 calipers
2. Swapping the non-M3 carriers onto the M3 calipers won't work
3. You can bolt-on the M3 calipers onto the non-M3 Kingpin, but you will need a custom rotor with a backspacing of about 1".. not worth it
4. With enough time and money, you can bolt on anything onto anything, but it becomes a ridiculous waste of money
5. To summarise.. refer to point #1 :D
discolite;446204 said:
Hmm that thread title says it all ... can they? If not how $$$ would modding to fit be?
ask Bro SC IS...think he did that for his ride if i remembered correctly
Like Rodney says, doable.
Nic if you can get the calipers, its doable. Call me and i'll tell you. Or just visit Rodney, it can be done there.
PS: sms you no reply bro. :(
go8868co
