Braking Calipers
Re: Braking Calipers
Doesn't that brake kit come with rotors as well?. You should always change em' as a set.. unless you tell me it was just the calipers for sale and you were wondering if you could just use ur original rotors back instead of buying a set of new rotors for the BBK. If that's the question then i do not think so, i think min rotor size is 332 or something like that. your current rotors should be too small.
i meant.... if the weight of the rotors are not gonna affect the pick up of the car that much. especially my car is just a 4 pot... is it advisable to change to that set of BBK including the rotors
Dude, ANY BBK is goanna be lighter than ur stock rotor and caliper,
the question you need to ask yourself is that whether you need the xtra braking power instead of wondering if stock rotors are lighter than the brembo ones.
caySman;266412 said:
if you can take the ugly look , go for the TE37 lah! cost wise, unbeatable, weight almost unbeatable, strength unbeatable, only the look like shit ...
You will see my new shoes 19in TE-37 White color soon..
TE is hawt la, where go shitty? The 18in looks fugly coz the spokes look so flat...the 19in is a different design...sms me your number, i hv the pic to MMS you 9819 0786
9kg 8.5J
10.5kg 12J
Another lighter one in my list was HRE C20......front was 8.8kg, rear was 10kg
But cost twice as much...Buay steady
9kg 8.5J
10.5kg 12J
Ho Say Liao... another brudder smitten by TE37...
if only had some money to change rims...
9kg 8.5J
10.5kg 12J
Jack where you buy the TE37? I think I can tahan the ugly look of the 18, because I cannot tahan the 19" ride (forum feedback) on a daily driver. In fact it will make me slower in any other place other than track because the bad ride affect my confidence.
You can shortcut my research, thank you.
Is 997GT3 and Cayman offset same?
If I buy, this one will have - CSC3. Lightness > PS2. Wear > PS2. and since I am not a race driver grip < ps2 is OK lah...
GT3 offset n Cayman is different in the rears...coz the GT3 wheel is much fatter
So for your Cayman ( and hence the TE37 ) , the specs they hv for you is
8.5J +50
10.5J +40...swee2x
Check out...light weight forged rims
\\\ Welcome to Champion Motorsport ///
bot my TE 37 from Leong Seng
8.5J +50
10.5J +40...swee2x
Tirerack has slightly different information ...
Front Fitment
18x8.5
Offset: 49mm
Bolt Pattern: 5-130
Rec. Tire Size: 235/40-18
Manufacturer Part #: WVDV49P8
US$$589 (each)
Rear Fitment
18x10
Offset: 42mm
Bolt Pattern: 5-130
Rec. Tire Size: 265/40-18
Manufacturer Part #: WVDY42P8
US$$659 (each)
9kg 8.5J
10.5kg 12J
jack..you champion... swee swee la!! white TE37.... slurp...
okup3
