Bulb symbol
Topgear98
My E90 external bulb symbol lighted up but I checked through all the lights are working. Any bros know what happen?
Thanks in advance
Re: Bulb symbol
most likely rear right brake bulb....hehe
just use the left lever and scroll to "system check"
press "BC" and hold it there.
there should be a CCID error code.....just google for the BMW CCID error code to find the exact problem
Bulb symbol
Coincidence. I just had all bulbs for the rear brake cluster replaced yesterday - the same warning light lit up. Glad the warning light has now gone away.
BMW knows how to get driver attention with the visual warning symbol and the gong chime - every hair stood up whenever I hear that chime during a drive. ;) well.... Shows that it works to get driver's attention....
Re: Bulb symbol
Topgear98;1080189 said:
Thanks in advance
Have you check the third brake light? That's one possibility that most people will missed out checking.
Re: Bulb symbol
Thanks. Will check that later.
Re: Bulb symbol
Where u buy all the light bulbs from?
Re: Bulb symbol
Check the license plate lights also. Mine gave a warning because one of the license plate bulb is flickering
Re: Bulb symbol
Try checking your fog light. Sometimes it could be due to short circuit at the bulb holder due to water corrosion.
Re: Bulb symbol
Will go to workshop to check next week. Thanks
Re: Bulb symbol
You got 2 rear brake lights on each side, left and right. So total 4 lights. When the primary light bulb blow, the secondary will be used. The primary is on the outer side and the secondary is on the inner side. You try to get someone to step the brakes for you, you see carefully if either side of the brake lights light up on the inner side.
Think this should be your problem.
Re: Bulb symbol
Yeap, mine was this problem as well. Having two rear bulbs each side is an excellent back up but makes it harder to detect.
A reputable shop will take a minute to find the blown bulb :)
Re: Bulb symbol
Thanks. Don't know that our E90 got 2 rear brake lights. Will check later.
nhacai188betmov
