Aaron_BMW
Dear all,
Just to share that I had suffered in silence for the past 5 months where my car has squeaky cabin noise.
To my discovery, it came from the door rubber seal which had harden due to old age.
The road movement had caused it to rub against the door frame which causes the squeak.
I had been recommended to change the whole rubber seal set OR spray the rubber lubricants to cure the noise.
However, I had found the simplest and cheapest solution which is to buy a 3M electrical tape and stick it along the door frame. You may also choose the transparent tape which best matches your car color.
The car is now running happily and quietly.
Please see the attached diagram and arrows below for a better understanding of how it's done.
