Can E46 rims fit E90?
Re: Can E46 rims fit E90?
krakenster;810203 said:
Hi guys, can 18" rims from E46 320 fit a E90 preFL 323?
must see what rims.....worried different off-set ( then must put spacer )
cheersssssssssssssssssssssssssssss
y the need for spacers? the rims on the E46 flushes well.
you reckon that the rims would rubber the inner fenders on my E90?
cause some E46 rims can fit buy will have sunk in look on the E90 .....thus need spacer...( best is to bring it to the tyre shop to test fit or check the off-set first before commit )
cheeeeeeeeeeeeeeeeeeers
:oooops: would rub the inner fenders i meant
hmn.... so LL, looks like the only option is to test out at a local tyre shop....
yes, to be 100percent sure.....for a peace of mind....
by the way what rims are those??????????????
cheeeeeeeeeeeeeeeeeeeeeeers
my answer is f10 stock 17" YES can go to e90 (1 size)
others 18 or 19 NOT sure
If you ask PML they will say NO NO NO (they are right becos thet F10 is made for F10)
pg88comim
