Changing A/T fluid
Re: Changing A/T fluid
Frens, I am ignorant on this. :thinking:
So changing ATF regularly will prevent gearbox from "kaput"?
Changing it regularly can improve smoothness of the transmissions during rides not?
How regularly need to change ATF?
Thanks.
Golf-mass;599724 said:
Just change ATF with ZF @ $210 . One question , there is no dip stick. to indicate the correct volume of ATF to replace , therefore mechanic top up ATF via pump till overflow . Is that the correct way ? Anyone out can share ? Thks
$210 is pretty cheap. How many liters did you require?
