Conforti CAI Installed + Questions & Review
Re: Conforti CAI Installed + Questions & Review
Sweet!!! Noice!!!! I likeeeeeeeeeeeeeee.....
L0neW0lf said:
Can I ask why? Tks!
Due to the difference in MAF diameter.
However, having said this... there are ways and methods to mate the filter to it.
One thing to note, if the heat shield is specifically for 6 potters, then it won't fit the Valve..
as for Wilson... *shakes fist* ahahahahahahaha
gabey said:
If you pushed it as far as it can go, then it should be a proper fit. Advice: Do not over-tighten because the circlip is clipping on the CF air intake side and not on the filter. Too tight and you may crack the CF tube. From here on, you can have a choice of cone filters to play with eg. Apexi, Blitz, K&N, Simota, etc...as long as the diameter fits the CF tube. If the intake pipe of the cone filter is too big (by a few mm), you can always bring it to a shop and lathe it to fit the CF tube. You will end up like me having many cone filters in the store room!! Have fun.
Hi Gabey,
Thanks, yeah will changing the filter change the growl generated from the CAI?
jaskin said:
Hi Gabey,
Yup. Different construction will give you different effects. The ITG provided is considered quiet! Some others like Blitz will give you more growl. I found the Apexi to be the best compromise between sound and performance but you need to shave off a few mm from the intake pipe in order for it to fit your CF tube. I am currently using the Simota. Low end is not good but mid to high end is nice. Ask around, you will be surprised how many types of air filter people are using. That will save you some moola also instead of buying one to experiment.
L0neW0lf said:
Can I ask why? Tks!
Different engine bro!
Conforti CAI is designed for inline6 engines!
So, it will not fit the 318 valve, also there ain't any 318 valve in the States....
'The Great White'
no wonder when i surf to find a CAI for my 318, i always see the manufacturers like AEM state that their CAI is only for 325 and above. So it's bcos the US do not have 318s.
So besides the GruppeM, what other brands are there for E46 318? GruppeM is a bit pricey but I am a CAI fan having used it before in my previous ride.
Seniors plse advise.
You can try DIY? I think some guys might have fitted a Simota Gruppe M replica on their 318s
hb88covn
