Centurion9990;872150 said:Click the search button.. There are countless threads on comparison of blackvue to itronics to finevue..
patpeh;872196 said:Thanks all. i did a search and found what I needed. I think the Black Vue is probably the favourite.
SpoiltBrat;872523 said:I installed ITB and now sianz. every morning error - high batt drain. always must remember to plug out at night.
airnow;873214 said:I have made an appt to install ITB but not sure which model to install yet. Mine is E93 so workshop need to check whether its possible to install rear camera. Anyone wanna join me? Thursday 12pm to 2pm at Kaki Bukit.
st8800;873152 said:U use any video cam under the sun that connects directly to car battery.... u will get the same battery drain error. It is not really an error because your camera is on parking mode and does actually use the car battery. U can either disable parking mode or just ignore the error.
There is also a magic box that can cut off battery usage once battery is below certain preset level.
SpoiltBrat;873516 said:I am using the powersaver. It is still giving the error every morning if I forget to unplug. This happens at night under cover. I turn on low sensitivity and only on impact for park mode. Could not see any video recorded at night so it did not come on. Still the error.
Actually was hoping for some night recording. Then, can send to SPI. :yikess:
