Re: Dilemmas - X6 or X5?
X6 any time, although i can't afford yet.....(X6 with twin turbo but X5 no turbo)
Good luck for your search bro...............
Cheers.....
2008 BMW X6 xDrive 35i Sport Utility Performance & Efficiency Standard Features -
Turbo compressor
2,979 cc 3.0 liters in-line 6 front engine with variable valve timing/camshaft and four valves per cylinder
Premium unleaded fuel 91
Gasoline direct injection fuel system
Main fuel tank
Power: 224 kW , 300 HP SAE @ 5,800 rpm; 300 ft lb , 407 Nm @ 1,400 rpm
2008 BMW X6 xDrive 35i Sport Utility Handling, Ride & Braking Standard Features -
Four-wheel ABS
Axle ratio :1
Brake assist system
Cornering brake control
Four disc brakes including four ventilated discs
Electronic brake distribution
Electronic traction control via ABS & engine management
Immobilizer
Stability control
Wishbone front suspension independent with stabilizer bar and coil springs, multi-link rear suspension independent with stabilizer bar and air springs
2008 BMW X6 xDrive 35i Sport Utility Exterior & Aerodynamics Standard Features -
Body side molding
Body color front and rear bumpers
Day time running lights
Driver and passenger power heated partial-painted door mirrors
External dimensions: overall length (inches): 192.1, overall width (inches): 78.1, overall height (inches): 66.5, wheelbase (inches): 115.5, front track (inches): 64.7 and rear track (inches): 67.2
Front fog lights
Projector beam lens Bi-Xenon headlights
Metallic paint
Hinge rear window with defogger and intermittent
Roof rails
Glass electric front sunroof
Trailer towing preparation
Underbody protection for fuel tank, for transfer case and for engine
Weights: gross vehicle weight rating (lbs) 6,085, curb weight (lbs) 4,894 and max payload (lbs) 1,191
Windshield wipers with automatic intermittent wipe and rain sensor
2008 BMW X6 xDrive 35i Sport Utility Interior Standard Features -
Air conditioning with climate control and rear outlet 2
Diversity antenna
Peripheral interior monitoring anti-lift anti-theft protection
RDS audio system with AM/FM and CD player CD player reads MP3
Automatic drive indicator on dashboard
Cargo area cover/rear parcel shelf
Cargo area light
Clock
Computer with average speed, average fuel consumption and range for remaining fuel
Full dashboard console, full floor console with covered storage box
Delayed/fade courtesy lights
Cruise control
Door ajar warning
Door pockets/bins for driver seat and passenger seat
External temperature
Driver front airbag with multi-stage deployment, passenger front airbag with occupant sensors and multi-stage deployment
Bucket electrically adjustable driver and passenger seat with height adjustment, five adjustments and tilt adjustment
3-point reel front seat belts on driver seat and passenger seat with pre-tensioners
Front seat center armrest
Two height adjustable electric adjustable active head restraints on front seats, three height adjustable head restraints on rear seats
Headlight control with time delay switch-off, dusk sensor and auto off with ignition active
Heated washer
Illuminated entry system
Internal dimensions: front headroom (inches): 38.3, rear headroom (inches): 37.2, front shoulder room (inches): 59.9 and rear shoulder room (inches): 57.0
Low tire pressure indicator
Memorized adjustment with three settings on door mirror position and steering wheel position with five driver's seat positions
Remote power locks includes trunk/hatch and includes power windows
Front and rear power windows with two one-touch
Front and rear reading lights
3-point reel rear seat belts on driver side, passenger side and center side
Rear seat center armrest
Three asymmetrical split bench front facing reclining rear seats with fore/aft adjustment and zero adjustments
Front and rear side curtain airbag
Leather seat upholstery with additional leather
Seating: four seats
Service interval indicator
Front side airbag with occupant sensors
Twelve speaker(s)
Leather covered electrically adjustable multi-function steering wheel with tilt adjustment and telescopic adjustment
Tachometer
Illuminated driver and passenger vanity mirror
Ventilation system with micro filter, automatic recirculation and active carbon filter
