ttee;457398 said:Is there any reason you do not use universal air filters?
Universal air filters
jason3s;457645 said:nice mod, was wondering when u'd be posting this since i chanced upon it bimmerforums.
Just curious, is that your expansion tank there right where the LHD E36s have the brake master cylinder? You went for a fluidyne radiator?
ttee;457775 said:I added a 6 inch fan (without connecting to power) in front of my air filter to helps increase air flow at high RPM, Not very useful for local driving.. It seemed to be working well when I travel in M'asia. Quite smooth. I have been doing this since August last year. I call this my mini supercharger![]()
joon;457786 said:My advice would be to remove the fan.. it will NOT improve airflow.. it's a huge obstruction, it will not add any improvement and it only adds turbulence, don't believe all the 'cyclone' intake bullshit... it would be better to construct a scoop or duct to channel outside air into the intake area, this is the way the race cars do it.. the F1 cars do it.. if properly constructed it can generate positive pressure on the intake at high speed
TobyNik;491174 said:Joon
Since you're at it.....I am sure you have seen R2D's brilliant work on the 2 air scoops attached right behind the kidney grills.....
So, what's your take on that? How much improvement (in your opinion) should one expect in a relatively affordable simple mod like the R2D scoops?
I'm a tech Noob.....
Just for discussion....
