detach8;756986 said:I have been fiddling with a generic OBD tool. My parcel with the BMW specific cable just arrived yesterday but I was not home to collect it. I've already installed INPA on my laptop and will pick up the new cable from post office later to see what I can do with it.
detach8;757194 said:Yes, I got a K-LINE/D-CAN cable with a USB head. It's basically a USB-to-Serial FTDI chip inside.
I just got the cable and spent almost 2 hours in the car trying to get it to work but to no avail. Being a techie myself this has proven to be quite challenging.
I'm going to do some searching online and at the same time spin up a brand new Windows XP VM (I run a Mac w/VMware Fusion) and reinstall everything step-by-step.
Having some of the stuff in German is not helping either.
Will post updates...
detach8;757595 said:NIL. Found out that my cable will only work on pre-2007 cars. Newer cars need DCAN and this cable only has K-LINE. And to make it worse I have the iDrive so I need a DCAN cable that has the 2nd KLINE bus removed.
If you have a pre-2007 ride (i believe pre E90-LCI) and is interested to try on my current cable, you can drop me a PM. I'll see if I can hook it up to my friend's 2006 E90 tomorrow.
I just ordered a new cable and am expecting to do some soldering work after I recieve it. Will keep you updated.
detach8;758847 said:BTW you don't want an old T30 I guess since you'll be running DIS in a VM. A more modern machine with sufficient compute power and enough RAM to run the VM is required.
detach8;761363 said:What are you driving?
You may need the newer INPA which I have. It has E90, or under Engine, you may find E90 engines.
For the ///M engines I think they have a special category.
detach8;761438 said:Nope, too much trouble for DIS - need to spin up another VM, set up networking... didn't bother. You might want to try though.
BTW where'd you get your cables and how much did it cost? I got mine off eBay ~$50 bucks.
