Dyno BMW???
NickyPower
I heard from some guys said we cannot dyno BMW due to the air flow sensors. At certain speed the sensor can only detect certain amount of air. So on the dyno machine the big fan will blow amount of 100 km/h and engine may spin more than that. Also the front wheel is not moving so dyno is not able to carried out.
Re: Dyno BMW???
You can definitely dyno the car. Its been done before. You will only have some problems if you have an M3. For more info, WILMAN!!!!
Re: Dyno BMW???
rubbish. all modern cars have MAF. just go and dyno your car lah. but keep in mind airflow is not fully replicated, so the numbers are at best an approximation. after the dyno your car's check lights will still be lighted up due to the confusion of the front wheels not moving but give it 50m of normal road travel and everything will be back to normal.
Re: Dyno BMW???
ho ho ho i guess i m the 1 that mix it all up. Yes recall liao he did told me is M3. So if have the tuning devices it will be good to be on the done on the dyno machine, so that every power is been capture
