alvin4c;145526 said:hi sszone,
mine had a taping sound after i got hold of my ride, upon inspection at BVO, they told me it is a leakage in the exhaust manifold , luckily not a very expensive repair as they basically seal it up which set me back by $130. .. cheers
Chewy;146186 said:Here is the list....Incredible! My jaws drop when i saw the bill....
It all happen when my timing belt snap when i start the car, so moral of the story dun change your belt only when it is about to snap...:furious:
1. cylinder head gasket- 111.50
2. Cam shaft- 262.5
3. 8 nos. hydraulic valve lifter- 168.00
4. Heater hose- 18.50
5. Rocker arm- 168.00
6. Timing belt- 38.00
7. Bearings (Small & Big including a gear set)- 88.50
8. Bottom Gasket- 85.00
9. Timing gear- 72.00
10. Pulse Generator sensor- 111.50
11. Cylinder head bolt- 50.00
12. Air con valve adapter- 50.00
13. heater valve- 40.00
14. Carbon Canister- 78.00
15. Plug housing- 18.00
16. Connector- 18.00
17. Tow chagres 45
18. Discahrge and charge aircon gas- 80.00
19. Skim cylinder head- 90.00
20. Labour Remove, reinstall cylinder head and grinding all valve- 360.00
21. Replace timing gasket, Remove install aircon compressor, alternator & bracket, oil sump gasket, heater valve, conver air con from R12 to 134a- 160.00
Thats all the above... reckon the price is all right?
GTV6;146210 said:Your lucky it snapped while the engine was being cranked up....if it happened during motoring speeds, you will probably also need to replace the valves, con-rods, pistons, wrist pins and maybe even the crankshaft...
E83_X3;146255 said:My VW Vento some 10 years ago snapped its timing belt while I was accelerating at speed (reached >140 km/h, up a flyover ramp when the belt snapped ... being a manual tranny, I remember being on low gear and on hard acceleration near 6,000 RPM!).
Everything died instantly.
AA's on-site diagnosis: Timing belt snapped, but distributor C&C's workshop didn't know the extent of damage until repaired. I was told to prepare for the worst .....
Good news came after the repair was done: Nothing damaged. Just changed the timing belt.
Was there something in VW engine design that prevented such a catastrophe?
The engine was a 2.0L SOHC 8v (the same one used in the first edition Golf GTi MkIII).
dpointt;146387 said:does this mean that one doesnt need to change the timing belt??
hmm....
jawzsg;146532 said:dpointt, I read from some literature that even with timing chain, you need to have them inspected at longer interval for undue wear but not likely they'll need replacement as often as compared to belt. My scrawny legs has broken bicycle chains before, hence I would think an engine may do worst. But then again, bicycle chain may be of weaker construction and quality.
