E46 19" Volks Rays TE-37 matt black 8.5 fr/9.5 r matt black
Re: E46 19" Volks Rays TE-37 matt black 8.5 fr/9.5 r matt black
eightynineten;794590 said:
that offset does not fit E60 5 series... FYI.
Hi Bro , What is the best offset for E60 . I am new for E60 , formally driving E90 and recently upgraded to 525i . Thanks in advance ...!!
Hi Bro, 5 series have an offset of 20 front and 25 rear mm for 9" J front and 10"J rear. So mine 8.5 front and 9.5 rear should fit properly, but front have to add a 10mm spacer if you want to look nice as it flushes on the outside.
Yes, E60 comes in ET20 all round, thus I said earlier you need to run a 15 or 20mm spacers in front. This will cut down from ET35 to ET20 when running a 15mm spacers.
pardon me but does this fit the X3 nicely? (flush)?
X3 offsets are ET46 front and ET51 rear, dont think can fit.
bearer;843590 said:
roger that. thank you bro
no worries bro; unless you dont mind the wheels sticking out a bit, which don't affect much since X3 suspension is very high so won't hit the fender hahah
Hi, like to check. 19" / 9.5 / ET 22 can fit a non-M E46 coupe withOUT modification to rear fender and no rubbing? I thought it should be 19" / 9.5 / ET 45
Do you have any pics of the rims on the car?
Would like to see what the offset looks like.
bayerische;913737 said:
sure cannot fit x3.......
Yes, in a way it won't fit :)
creative_tec;913764 said:
Able to fit Z4 E85?
the old Z4 has no problem, the new one should be not a problem as well.
its meant to fit the E46 M3 Bro :) For non-M you might need to roll fender.
you meant on the E92 or E46?
e46 m3 and e46 normal i think the offsets are different though
BMW E46 M3 offset: Front: 8.5"x19" ET 30 - 35 & Rear: 10.5"x19" ET 20 - 25.
ae888soy95
