e46 transmission oil
Re: e46 transmission oil
No Bro...When you get the opportunity to get close to the draining trans oil, take a whiff. It may smell burnt and that is not good. When BMW specs the oil and says it is lifetime, they take into consideration that you will change the trans after 150k km or so.... so duh....99% of drivers do not reach 150K km in the 3 yr warranty period.
The oil is not gonna cost you much compared to the replacement cost. IMO, change the oil..
So does that mean that we change the oil only when the reaches about 150k?
as long as its done properly, changing oil is a good preventive measure and can help lengthen lifespan of the box, especially in traffic conditions here which put more strain on Auto boxes. but not sure how often BMW drivers here do it.
Bro, should not wait until so late. After about 1 yr or 20 000km should change the ATF. Can see and feel the difference. Fro brand new vars, after the first 5000km, should change the oil cos the initial wear in metal particles would have dislodged by then.
Thanks for the reply Rod. Looks like I'm due fro an oil change then.
Bro, good thing to change the ATF. While you are at it check out the rear final drive oil too. That's a small incremental cost too.
Ok. Will do that. Kum sia.
Got mine changed at 55,000km mark. Not expensive to change. Around $120 for a 5 series if I remember correctly.
T6, was there any difference after you changed the trans oil?
Bro was that inclusive on the rear final drive oil as well? I assume you got it done at BVO?
Thanks guys... better safe than sorry...$100 over dollars... don't drink for one night hahaha..
just a quick one... if the average tranny life is about 150000km... by changing oil, how many more kilometers can it extend it by?
however, i fully agree that oil can & will break down over time.
Wah I dunno, yes, was done at BVO, they recommended ATF oil change and I said ok haha.
Kum sia. Will change when my mileage reaches 50+k.
Actually, don't have to wait till then. I might be wrong, but theoretically, you should change all the "first round" of oil that comes when you recieve your ride after they reach certain mileage..like engine oil after 7k, tranny oil after 5k etc..
Aiyah you know me lah. Just simply hate to hang around workshops.
SL2 said:
Actually, don't have to wait till then. I might be wrong, but theoretically, you should change all the "first round" of oil that comes when you recieve you ride after they reach certain mileage..like engine oil after 7k, tranny oil after 5k etc..
Agreed. The only reason I changed the ATF at 55,000km was coz that was when I bought and took over the car haha.
Yup, chould change thereabouts.... The gearbox oil is the most punishing oil in a car becos of the constant shearing forces involved when metal meets metal. To improve the shear capabilities of oil, manufacturers add in sulphur into gear oils and that is why they stink. The sulphur thickens the the oil and does not allow it to be squashed out between metal surfaces. In ATFs, the conditions are worse. The torque converter allows oil to run past the plates when you are at the lights and this heats up the oil and breaks it down slowly. And that's why you have a oil to water ATF cooler at the bottom of your radiator. IMO the cost to replace the ATF is far far cheaper than replacing the tranny. Oh yes almost forgot. The strainer in the gearbox is not critical for replacement everytime as once the run in ATF is changed, there is very little metal left in the oil and thus not too dirty. Anyway the strainer is alot more porus compared to a metal filings size. It is the job of the magnets in the sump to catch the metal filings. The strainer is to prevent chunks from entering the hydraulic system.
Where do the chunks come from? (Try moving forward and engaging reverse without stopping.....when you hear the grinding moise, metal chunks are being developed....)
