E60 acceleration problem from traffic light
iplaygolf
Hi all,
I searched the forum on acceleration problem but did not find any relevant topics. My 6.5 yr old E60 has started to experience jerky drives from traffic lights.
Symptoms are slow acceleration no matter how hard i stepped but ok later, and occassionally, 2 secs of knocking sound from the wheel, its like the car has problem gripping onto the road but my hankook tyres are only 20K new...hard to describe...hope you know what i mean.
Help!!!
Re: E60 acceleration problem from traffic light
Could be a range of possibilities but the usual culprits are fuel pump and crankshaft
Knocking sound is not tyres, could be anything as well..like control arm bushings worn off or suspension faulty
you can try checking on a few areas:-
1) Fuel Pump --- too old?
2) Fuel Filter --- Dirty ?
3) Catalytic Converter ---Clogged?
4) injector --Clogged?
5) Mis-tuned --- IF you did tune your car before, check the above before re-tune.
As for the Knocking sound ..."2 sec...gong gong sound" as per MW has mentioned the possibilities ( suspension system, bushes, collapsible steering column...).
hope these helps :)
i vote for 1,2 & 4....haha
Hahahhaah... bro u are like answering multiple choice question.
However, 1,2,4 shares the same chain. :juggle:
Thanks! I will be sending the car to PML next week....hope small issue...
Since car out of warranty already, no need to send to PML. You can try some of the sponsor workshops here, which provide excellent advices at reasonable prices. I would recommend R2D at Unity Centre, Bukit Batok.
Slow means there is lag when you press on the accelerator? Then, at some point the power comes on? Or slow means something is slipping or holding you back then suddenly all seems to move?
I experience something less dramatic then this before but after the drive up to Penang and back, i can feel the car is so much more willing to rev and move.
Maybe time to take a holiday in Malacca or something and let your car breath a bit.
maybe is the coil over,, i just got my change..1 pc $178 have to change 6pc..hope it help.
i have the same problem for my E90...i fast hand fast leg sell it away after visiting few workshop and still can't gt it fix.
If its fuel pump and filter - goto the workshop with quarter tank or less and some petrol.
Hello all...
I took the car to PML for a test drive by one of their technician. His verdict is gearbox malfunction thus acceleration is slow but normal after 60km/h.
Arranged a diagnostic test to find out the prob. Most likely gearbox kaput and now have to decide whether to repair (at lowest cost possible) or change car.
Current ride is 6.5 yrs old with 115K km.
SpoiltBrat;833737 said:
..... Maybe time to take a holiday in Malacca or something and let your car breath a bit....
U refering to 'Clear Carbon' :lol: :lol:
Got car checked at PML. Was told transmission unit issue and quoted 11k for a brand new set. Somehow, the service adviser could not articulate the issue well. Was told gear box ok, but clutch worn out and cannot be changed. Is this true? Topped up transmission fluid, reset the software and now the car does not feel so right.
Help!!
Help!!
Bring it to one of the gearbox specialist workshop - do a search. Should be cheaper.
Hi All,
Sorry if this is a repeat question, but would appreciate anyone who can help to answer this question I have i.e. my E60 (4 cylinder) had an engine oil leak due to too much oil being added in the last change. As far as I know, the recommended amount for this model is 4.25L however is this the correct amount? I can't seem to find any further info by reading the manual or via the forums. Any help would be appreciated, thank you in advance.
Big thanks to all bros here. Brought the car to R2D Autoworks and had it restored to good health (gearbox rebuilt) by the team.
Good experience at R2D. I would recommend it to bros here who have the gear jerk issue.
Will be going back for a new set of suspension and regular servicing.
What happen to your car? And what was your damage$?
gemwinnavy
