Percival
S O L D
Hi, I have the above mention for sale. Note that the front & rear linkage will NOT be available. You can use back the stock linkage.
HUGE difference in terms of handling if you're using it with stock suspension, but it does make a difference with aftermarket suspension as well.
Looking at $500. Please sms 81888941 for enquiries. Thank you.
Please refer to description below ( extract from Hotchkis website )
Application: 2006 to 2008 BMW E90 Sedan & E92 Coupe 335i ( xi models excluded)
Front sway bar-lightweight, durable 1 1/4 (32mm) tubular steel (95% stiffer than stock)
Rear sway bar-lightweight, durable 5/8 (16mm) tubular steel (105% stiffer than stock)
Precision adjustable front end links w quiet operating heavy duty ball joints.
Precision adjustable rear end links w quiet operating heavy duty ball joints and high articulation rod ends.
Greasable polyurethane bushings and heavy duty mounts included.
Autocross and track tuned for maximum performance improvement.
Finished in durable gloss gray powder coat.
Benefits:
Increased Traction.
Reduced Body Roll
Increased Vehicle Stability
Crisper Cornering
Additional Information:
Enhance the cornering performance of your BMW with a set of Hotchkis Sport Suspension sport sway bars. Our 335I sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the 335I has excessive under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greaseable bushings, and adjustable Heim joint end links.
Benefits:
Increased Traction.
Reduced Body Roll
Crisper Cornering
