I am using E90 325i 2010 model. I kick myself as i adjusted the wheel alignment recently 6 months ago and now its been pulling left or right slightly. I have done it 5 times now , give up. Where should i go to fix this nightmare ! Tks guys
Anyone faced squeaking noise from panel (dash board area) when driving and ways to rectify to reduce/eliminate squeak noise.
bro Kawan,
wao i like your rear spoiler
My E90 think started to 'eat' oil liao. the engine oil level indicator which has 4 markings has now gone to the 3rd mark...
after driving for around 5k km. is that normal for a 6yrs old?
should i be alarm with it? or wait till the engine level oil indicator to come up?
thanks
bro Kawan,
thanks
The squeaking is recent after change of suspension to coilover. Lower control arms/ sway bar links/ upper thrust bar also changed. Squeak is from driving of any surface of road. Could it be the stiffness of suspension?So far my 11 year old E90 has been free from squeaking noise. As such, I don't think the cause may be due to ageing.
Is the squeaking noise only being heard when you are driving over humps/uneven road surfaces ?
To pinpoint the culprit may not be easy but I will go along in these direction if I were you:- (assuming the squeaking noise only occured recently)
1) is your dashboard top, glove box and door front door pockets clutter free ?
2) did the fuse panel cover in your glove box come loose ?
3) is your dashboard recently been dismantled ? (eg. to replace AC cooling coil)
4) did you recently install new HU or front speakers that involved removal of door cards/window sails ?
5) did you recently install in-car video cam that involved removal of A-pillar or rain sensor housing to hide cables ?
6) did you recently replace trims/parts at dashboard area ? (eg. replace a faulty cup holder/centre speaker/climate control panel).
Awesome got renewed coe kakis! My pcd rear sensor came off. Didn't realised until I parked it just now and came on the sign!
Thanks.
My model is E90 325i. mileage ard 85k already
I change the eo at ard 80k thus after 5k it start to eat.
Shall i top up some eo to ensure the eo is sufficient? or see and monitor if the level goes down further?
Thanks
Which year and engine model is your E90 ?
2006 320i.
Previously what EO were you using? And what are you using now? Hopefully you're not using an EO that easily evaporates for our hot SG weather.
If the EO level is between Min and Max, then you're OK. I would keep a 1 litre spare in the boot, monitor situation and see how.
Hi bro care to share what are the benefits in upgrading to M3 control arms? ThanksIf that's the case, you should focus on these newly installed suspension components.
1) Are they brand new or used ?
2) Are all the components specific to your E90 model ?
3) Have they been properly installed and proper wheel alignment done ?
I suppose you have upgraded to E9x M3 control arm components ? If you have xenon headlights, did you change your headlight leveling arm to the M3 ones as well ? Your original one cannot be re-used.
I've changed to firm suspension before but I experienced no squeaks with my E90.
I think it'll be good for you to go back to the same workshop that installed your suspension for troubleshooting.
Sent from my SM-G955F using Tapatalk
