Ahbengdriver said:E90 must warm up first then drive off meh? damn, no one told me before.
but I usually just drive hard to warm it up , obviously its the wrong way to warm up.
adsnx said:i did asked the service advisor & he said its not necessary to warm up ...gd thing also cos i always need to rush for work.
There's no temperature gauge in E90 & cant check thru the on board screen..i still wonder wat happens if the temperature rise.
bmwF1 said:If you need to idle for 5 minutes, I think it is better to turn it off. You will be burning petrol and polluting the environment. However, if your car is not properly warmed up, it is better not to turn off the engine and leave it on if you can.(ie start and drive for 5 metres)
Ahbengdriver said:I got a stupid question. :screwedu:
If my car is parked under the sun, which means it is warm or hot...does it mean no real warm-up is required ? bcos car warm means engine also warm?
