E9X Coding
Status
Not open for further replies.
berntham
UPDATED with new features coded.
Hi everyone, I'd like to test the interest in the coding of E9X cars.
MODERATORS, please advise if this is the right thread to post in...
I've recently managed to code my car with the following options;
1. Always-on instrument cluster lights (with light switch in 0 position, DRL on or off) - this drove me nuts for the longest time as most modern cars already have this feature...
2. Aircon set to internal re-circulation PERMANENTLY (another one of my top wishes, finally discovered and coded! note that the car will still open the vents after a few minutes [likely for safety, to allow internal air to 'equalize' with external air... however, the setting is retained so on engine start, the vents will move back to a 'closed' position)
3. Double blink hazard lights (more visible)
4. Digital speed display (engine speed, different from speedo speed)
5. Folding mirrors activated from key fob (i discovered that this can also be activated from the door handle, if comfort access is present. just press and hold! )
6. auto-dimming side mirrors disabled. although center rear view mirror will still dim, somehow it feels less than before. side mirrors no longer dim when bright lights from behind are detected. this used to bother me as old motorbikes with weak headlights could not be seen with dimmed side mirrors...
7. warm check on angel eyes and reversing lights disabled. prevents flickering when starting car due to the use of LED bulbs.
8. windows will now roll up continuously with door open after a single full switch. This was originally disabled for 'safety' but I've found it annoying especially on passenger side, when they arrive (and I'm waiting with windows down), I want to quickly roll up both windows.
9. Disabled Tail Lights when Daytime Running Lights are turned on. This is the current 'trend' for most conti cars.
I did this with a cable and software from BMTechnic.com (NOTE, BMTechnic has closed down likely due to copyright issues. our bro PixelBug has gone the DIY way and succeeded too)
as you'll read online, there's a whole bunch of features we can code on our cars, but it's a lot of work (and risk) to find the right values.
Is anyone out there also keen to try this out?
A larger group of people looking at it will reveal more info on where we can code.
Shops will charge 80 to 100$ PER FEATURE and i've already recouped my cost on the cable...
let me know your thoughts....
Re: E9X Coding
i'm very keen if you are able to enable video in motion feature. don;t mind paying to help cover your cost too.
Re: E9X Coding
That's one of the most complex things to code and I'm looking at it myself too... Hence my ask for more folks to share and test....
Re: E9X Coding
Bro is it possible to code for digital speedo. Willingnto share your cost as well! Tk u..
Re: E9X Coding
bally;1016168 said:
Got my folding mirror and digital speedo done up by a coder too :)
Cool stuff!
Folding mirror feature is feasible provided our mirror c/w auto folding mechanism right..?
Thanks.
Re: E9X Coding
Not sure but can explore....
In fact, welcome lights can be in the form of fog lights, headlights, angel eyes, etc....
Beerbelly;1016311 said:
Any chance on PFL E90 welcome lights when you unlock your car?
Re: E9X Coding
Deathchant;1016141 said:
Hi Bro,
Is the coding in ladder logix? I'm interested in coding as well.
Uh, I'm not sure what you mean by that but I've definitely not come across that term during my coding and research...
Re: E9X Coding
maybe you're looking/researching at the wrong place... FXX coding were ported from EXX series, most were similar (that's how the FXX community learn)... VIM shouldn't be difficult (for FXX)
Re: E9X Coding
Thanks.
Thanks.
Which means we need to have the side mirror replaced with the auto folding kind, must be exp.....
Re: E9X Coding
vexxus;1016512 said:
Thanks.
coding can only enable or disable a feature that is already present in the car physically...
for instance, auto dimming mirrors (if present, can be set to turn OFF)
Re: E9X Coding
It will be nice to be able to code my angel eyes for the welcome lights, dun mind to share the cost too.
Re: E9X Coding
Oh Ladder Logix is mostly for industrial equipments.. I heard from one friend that coding uses ladder logix but cannot confirm so I thought of checking with you.
No problem.. Let's see what we can do. I am also interested to have my angel eyes on when i unlock the car when the lights switch is put to off.
I do notice that the only way to have my angel eyes on when I unlock the car is if the lights switch is put on auto.
Re: E9X Coding
Wah so steady ah?
Everything also can code.
Can code for a beautiful andromeda in my passenger seat each time i turn my car "on"?
Re: E9X Coding
interested in the folding mirror feature. pls sms me at 98488158
Status
