E9X Coding
Status
Not open for further replies.
Re: E9X Coding
it seems there're many folks asking me to code this and that :sickinbe:
nobody wants to learn to do it??
organize meetup to do mass-coding for a fee??
let me know your thoughts....:)
Re: E9X Coding
rvt;1017445 said:
Wah so steady ah?
Everything also can code.
Can code for a beautiful andromeda in my passenger seat each time i turn my car "on"?
i also want LOL
Re: E9X Coding
berntham;1017910 said:
UPDATE: aircon recirculate switch setting to always ON discovered and coded!!
Not exactly sure but older e90s can't be coded for this. I think those 2009 and before.
Re: E9X Coding
Reminds me of someone ....... He did just that.
Re: E9X Coding
Haha! I did say I do ladder logix and am interested in coding... Haha...
Re: E9X Coding
uh, i dunno what's ladder logix :p
i'm beginning to explore ESYS coding for the newer F series...
Re: E9X Coding
Im only interested in DVD on e move.. Let me know if its possible.
Cheers ~~~~ :)
Re: E9X Coding
Thanks bro for helping me to code my E90 prefl on setting the internal air circulation to always on and auto folding side mirror when I lock and unlock my door.
Really happy now that I dun have to press extra buttons every time I board car.
Re: E9X Coding
I want oso. Pls help.
Re: E9X Coding
I also dunno what kind of coding used for the cars.. maybe we can arrange a meet up
heh heh!
Re: E9X Coding
To TS ....
can you code auto dim function for side mirrors ?
Re: E9X Coding
Interested to code for E90 prefl on setting the internal air circulation to always on and auto folding side mirror when I lock and unlock my door.
Re: E9X Coding
I also interested but i thought Pre FL do not have auto folding mirror?
Re: E9X Coding
That's an option (i guess) when purchasing new from agent.
Only a handful of Pre FL E90 c/w auto folding mirror, realise that when i was shopping for my ride..
Re: E9X Coding
Hi TS pls advice,
Interested to code for E90 prefl on setting the internal air circulation to always on and auto folding side mirror when I lock and unlock my door too.
Thanks n rgds.
Re: E9X Coding
Finally successfully coded my car with some interesting features:
1) Digital speed display on instrument cluster
2) DRL with License Plate lights
3) AE as DRL (having issue using my BC to activate, finally get it working with coding)
The cable is cheap at about US$20, the coding software is free on the internet. The coding process takes less than 5mins to code if you find the right code and know what you are doing. Previously, I get Munich to disabled the seat belt alarm, and central locking when the car is travelling, and they charge me $80plus for it!
The most challenging part is actually getting the software to run on the laptop. It took me 1 week to get the coding software running on my laptop, and 3 days to successfully code my first features :)
There is actually all kind of interesting codes available for E39/E46/E60/E70/E71/E90, F10/F20/F25/F30. Some of the features has already stated in this thread.
Other features like:
Convenience
•Start the engine without having foot on the brake
•Enable / Disable seatbelt butlers
•Do not automatically turn on AC when climate control is set to Auto
•Make wipers wipe to the end when engine is switched off
•Display Digital Speedometer in the cluster
•Display instant MPG in the cluster
•Fuel Tank reserve warning comes on at 1/8th tank or of ¼ tank
•Instrument cluster lighting always on
Doors, Windows, Sunroof, Mirrors
•Turn off the annoying Door Dong
•Close windows / sunroof with Keyfob
•Unlock all doors or just drivers door when key is removed from ignition
•Disable / Enable Auto dim mirrors
•Disable windows safety feature (opening door does not stop windows)
•Fold side mirrors with Keyfob
•Auto close sunroof on rain from full open (has warnings)
•Auto close sunroof on rain from tilt
Entertainment
•TV in motion at any time
•DVD in Motion at any time (complex)
•Enables DVD playback when car is stopped regardless of what gear but not in motion.
•Select CIC audio outputs (for use with external amplifier)
Gongs and Dongs
•Turn off seat belt chimes
•Enable / Disable display and gong when key is left in ignition
HVAC
•Enable REST (residual heating) function with the ALL button
•Enable parked car ventilation option
iDrive
•Lock / Unlock Beep option in iDrive (enables submenu in iDrive)
•Allow control of auto lights and rain sensor in iDrive
•Disable iDrive legal warning
•Add submenu to iDrive to enable Daytime Running Lights (DRL)
•iDrive default screen → Communications or Entertainment or Navigation
•Show and propose fuel stops in iDrive navigation
•Add extra menu to iDrive to select day mode, night mode, auto mode
Lights
•Enable Follow-me-home lights
•Increase Angel Eye Brightness
•Turn various Bulb Test Warnings on or off
•LED Tail light retro-fit
•Side Marker Delete
•Double blink hazards when a button is pressed
•Enable Welcome lights (any or all of Front Fog lights, low beams, rear fog lights, rear licence plate lights, Angel Eyes, front turn signals, rear turn signals)
•Disable tail lights when DRL is on
•Enable DRL (can be Angel Eyes (AE) or High Beam)
•Remove adaptive headlight error message
•Enable Brake Force Lights
•Enable Fog Lights to stay on when high beams are flashed
•Enable Fog Lights to stay on when high beams are on
•Enable both Bi-Xenons and Halogens as High Beams
•Enable/Disable headlight washers
•Change sensitivity of auto-lights for cars without iDrive
•Xenon headlights retrofit
Lock Up / Unlock
•Close windows / sunroof with keyfob
•Enable / Disable internal central locking button with key only in ignition
•Auto eject of KeyFob when engine is turned off
Mirrors
Miscellaneous
•Enable the complete deactivation of DSC in the mdrive menu
•Change the level of the alarm chirp sound
•Disable the Digital Speed Correction Factor
•Enable Shift Suggestion in 6MT cars
•Display Cruise Control Set Speed
•Drivers seat memory options in cluster
•Change incoming call ring tone
•Enable Bluetooth, CDC, USB and SMS management from BMW Professional Radio
•Disable Tyre Pressure Monitoring System (TPMS)
Safety
•Enable Panic Mode (Hold trunk button on FOB for 5 seconds)
Status
