Hi Bros,
I've been on Mobil 1 5w30 engine oil for a while now. Recently, I'm experiencing super high engine oil consumption. I need to top up 1L of engine oil for every 1000km.
I have no leaking problem as I have fixed all my oil leaks and changed most of the seals and gaskets. The undercarriage is dry as per my last oil change about 3 weeks ago.
Wanted to check if anyone had encountered the same problem. If so what did you do to fix this? Is this normal?
I understand that normally for such high engine oil consumption, the normal assumption is that my piston rings are worn out and need replacement.
I also understand that some folks have advised changing to a higher viscosity e.g. 10w40 or 10w50. Does this help at all? I would assume changing to a higher viscosity engine oil only masks the problem and is not a permanent fix.
Any sort of feedback is appreciated.
Thanks in advance..
Thanks in advance..
