tortoisespeedsir
Re: Engine consuming engine oil - 2005 Pre-FL 320i
Which gasket? Is it the valve gasket? The one where the engine oil cap area is leaking? If yes, should cost less than sgd1000.
propertyhans;676177 said:Hi
I went to check aircon but was told engine leaking...sigh.. Was quoted 1.8k and need 2 days at a workshop at bukit merah. For my case Oil leaking is visible in the engine compartment but so far no fault signal and no problem with ride. Engine oil meter reads healthy. Mechanic say still can use but don't want to risk it. just wanted to check with those bros that changed gasket...what was the damage?.
Driving '07 e90.
Thanks!
