Engine Mounting - replacement - BMW E90
Aaron_BMW
just for sharing,
the replacement of engine mounting as the old one is loose and caused my car to vibrate like hell.
simple 30 mins job
the old damaged mounting
brand new mounting
location in the engine bay
Re: Engine Mounting - replacement - BMW E90
Did you do the transmission mount along the way ? Normally done together.
No leh...
I got no idea.
I assume my transmission mounting is still fine???
replaced or upgraded to 335 mountings for more omph ...
unless previouslyalready done. Both are to dampen vibrations so normally do both together since the cost not much.
Aaron_BMW;917609 said:
No leh...
I got no idea.
Sound logical if the engine side mounting is changed, trans side will be lower with the old mounting..
I changed both at the same time.
Done mine, both changed to 335 mounts earlier in the year.
any difference or i should ask any improvement - butt felt?
Heard the 335 mounts are harder, but after install, feels the same or vibration on steering wheel much lighter.
Did mine as preventative maintenance rather than replacement for worn out mount so maybe not much difference :)
actually, i expect increased steering vibration (or feedback) since the mount is harder ...
Would u all consider to install the engine damper?
Holds the engine firmly and reduce transmission power lost
Try M3 engine mount, the steering wheel vibrate when stationary. But when step on accelerater pedal hard, super sheer driving pleasure..
That dont really help much for my previous ride as compares with PU mountings.
Then again some may find it otherwise.
Cheers ~~
which one are you referring to ?
Bro, i need to change my engine mount also. Can Pm me the workshop that done your engine mount and the damage?
PM replied
Yeah, with the 335 mount even though i don't really feel any difference, revving the engine hard i guess is smoother, cuz you don't feel the engine 'twisting' as much.
Yes, the engine dont "twist", immediately translate power to your wheels, very good when picking up at traffic lights and over-taking...
Hema
