exhaust for e93 335i
Re: exhaust for e93 335i
The exhausts are working, just that at idling, 1 will be working only as the resonator flap has closed off 1 side. The golf tee mod is to permanently open the flap so that the exhaust sounds louder. And when u do a cold start, the car is louder as the revs start off at 1.1k rpm and slowly lowers to 650rpm.
Right side will be working during the cold start, the left side will only open at higher RPMs, that's where the resonator flap is. U just have to look before and u can see a black tube going into the muffler box. Remove and clamp it. The reason for calling it the Golf tee mod is cuz pple use a golf tee to plug the hose.
Funny, but the golf tee mod cured my urgency for a new exhaust. I'm happy with the result.....for now :D
Stefan, what benefits do you get from the mod? louder or performance? :)
its just louder :) It permanently opens the resonator flap so you can exhaust gases coming out from both exhausts!
Better read the US e90 thread in detail. I won't do this mod after reading thru.
If you use a ball bearing, it should be O.K. Don't disconnect the plug...that's bad.
The ball bearing size should be 7/32 inch or 5.556mm, or am I wrong.
What is the size of the bb that you used ?
I used a 4mm ball and it's fine...easy to take out if you want to reverse the mod.
