F/s Oem Csl 19
Re: F/s Oem Csl 19
wilman2772 said:
For E90, rear CSL rims will fit! but front have to add 2mm spacers!
Bump bump for 14m3 sale....
'The Great White'
Thanks wilman2772 for clearing that.
Re: F/s Oem Csl 19
RaptureM3 said:
Hello..
Were you at the EXPO last night (11/11)? Saw your car there.. I think. Unless there's another E90 3 around with M6 rims. :)
P.S. Good luck with the sale, 14m3!
yes i was there looking for makan. there is another E90 on M6 rims and same color no, XXX 92 X .... same same.
bt
Re: F/s Oem Csl 19
rex7_vtec said:
14m3: sorry to hijack your thread. But since we are on M3 rims issue I just want to ask this question. Might assist you alot in your sale too
bintiong, E46 M3 rims can fit E90??
yes, as wilson had said. they can fit only thing is the front is a bit sunken if no spacer added.
the E90 is a diff car & is a larger one also, in the states a lot them are riding on OEM M3 18" rims & even OEM M3 19" .....
i am sure with this info his rims will be going going fast.
bt
Re: F/s Oem Csl 19
Now OEM M3 rims are worth more than ever before....swee2x..
Re: F/s Oem Csl 19
Hehe, typo error, it's 20mm, not 2mm....paiseh....type too fast liao....
'The Great White'
Re: F/s Oem Csl 19
lefortez said:
would these fit a e36 328 coupe?
As a set , nope
but u can fit in 4 pieces of the front ones.
Re: F/s Oem Csl 19
Wats your budget bro??? Do you know the price for original 19" M3 CSL rims????
'The Great White'
Re: F/s Oem Csl 19
'The Great White'
HI Wil, do you happen to have the 20mm spacers?
Re: F/s Oem Csl 19
Check with South East tires re spacers. They usually have the Eibach spacers in stock.
20mm is surely a lot. I think 10mm should suffice.
Just for comparison purposes for 18in rims (non M cars)
E46 offfset is ET47 front ET50 rear for 18" wheels
E90 offset is ET34 front and ET 37 rear for 18" wheels
Thats a 13mm difference or just over half an inch
In addition, Offset numbers mean nothing without comparing it to the width of the wheel.
Given the OEM M3 rims (either 18 or 19 ) are 8J with offset +47 in the front (similarly to OEM CSL's), that means if you put the front rims onto E90, then to make up for the correct factory offset, CSL front rim is short 13mm.
Having said that, the CSL front rim has 8.5J width (vs the other 8J OEM M3 rims) so by putting a 10mm spacers, you are already pushing out your rims offset (technically speaking) by 10mm hence your offset now becomes +37 ( so short 3mm from the E90's factory front offset)....and then coupled with 8.5J width of CSL rims......that shud be a perfect fit.
In other words, 10mm spacers should suffice. 20mm will push the front set up abit too much.
Those who are considering buying the rims and have a little doubt bout the fitment. Call Ah-Ho at S.E tires. He's the expert when it comes to this.
Gd luck again your sales:)
Re: F/s Oem Csl 19
Thanks TripleM for the insite on wheel fitment. Still available.
Re: F/s Oem Csl 19
Can someone advise if these CSL rims are placed on an E90, what tyre profile wld be required for both the front and the rear? Got a fren who is interested and was told he needs 235 for the front whereas the E90 manual and side door panel states 225. He seeks clarification:)
Re: F/s Oem Csl 19
E90 manual got state that the car can fit 19" meh????
Duh! :lol2:
'Clan Master'
Re: F/s Oem Csl 19
Duh! :lol2:
'Clan Master'
Wah lau, how I know.... the E90 owner told me one keke.
Re: F/s Oem Csl 19
235mm width for the front tires are normal.
In fact 8.5J can take in 255mm (assuming no rub ) but that's not recommended.
Re: F/s Oem Csl 19
I'm interested in the M3 CSL rims if its still available.
PM me for your price. I owned a e46 M3, so this upgrade is just nice.
Re: F/s Oem Csl 19
Great rims,
U wont regret....gd luck
Re: F/s Oem Csl 19
Pm'ed sent. Thanks for your interest. At this time, its still available but have a feeling it wont be for long.
Re: F/s Oem Csl 19
Bump Bump , can somebody buy off the rims, before i get 2nd thot but them again.
good luck.
bt
Re: F/s Oem Csl 19
good luck.
bt
Thanks tbt for the bump. Still available.
pg88comim
