f10 520i suspension one side high, one side low?
Re: f10 520i suspension one side high, one side low?
St8800 u right, need to use 5 fingers to measure, indeed my right side front is lower than left side front.
Just check my 2 weeks old f10. On the driver side, both front and back has the same clearance.
But the front passenger is higher and the rear is much lower. not sure if it is the exhaust but I doubt so.
This is very common for many german cars. They are first designed for LHD markets. Since the driver is seated on the left and steering rack on left, they try to balance it by placing engine parts slightly to right and fuel tank also right side. When they are building for RHD market, driver and steering all shifted to right, but the engine, fuel tank still continue to be on the right so naturally the weight of car is concentrated on right side.
And one more thing, whatever you observe is when you are standing outside, once you sit inside it will sit even lower on right side.
I'm going to bump this old thread. I think I'm having the same issue with my F10 rear. Driver side rear is lower... not by a bit, but its quite significant that you can tell with the naked eye. It's not supposed to be SO obvious (this is not my first BMW!). And the F10 is supposed to be better engineered for this RHD/LHD thing, i.e. even the battery has shifted to the middle.
But I have installed M-sport suspensions myself, so I can't bang table @ PML/MA. Going to take a trip down to R2D to have it looked.
Slow_Poke_Driver, what was your conclusion? F*** it and drive?
If due to extreme uneven weight distribution, you may want to consider precision alignment where alignment is done with the driver on board. This is what rally drivers do....
Meek, you saying I'm fat right!!!!!!
Meek;977534 said:
Dun put words in my mouth.... :D:D:D
u still dare to laugh!!
Just live with it loh, bo pian. Lazy to go back kao bei. Initially thought I will sell this stupid car away after a year, at most lugi 30k nia...but with the way market is moving, seems quite difficult to get a decent price.
On the more positive side, some how the lower side looks sibei chio.
Slow poke and detached8 shud get together...
Sounds sibeh gay...:D
Eh, why u so biased. Ghey cannot meh.
Slow_poke_driver, lai let's have kopi.
Sekali we swap our springs - I take your high side, you take my low side then our car all level liao. HAHAHAHHA.
Ai mai, we go R2D tomorrow night see wat dr rod say.
You see you see.... 50 shades of ghey coming out liao.
Swapping parts next swapping liquids... fuiyoh.
Ps. Can i come and watch ah? I bring back your nasty 3in1 for you.
Slow_poke_driver;850591 said:
Today I was looking at the car...then I thought that driver side looks better than passenger side.
See and see then realised that the rear suspension height is totally different on both side. Driver's side rear suspenion wheel arc and tyre only got 3 fingers. Passenger side can put in 4 fingers. Both front left right are the same.
Rear suspenion height left and right differs by 1 finger, Is it normal or not?
Due to fuel tank? But I only got 3/8 tank...so at most is 20kg nia.
Hi, i realised the same 'problem' when i got my f10 in the beginning of the year. Checked with pml and they confirmed it is the design. I didn't believe so went to the showroom and premium selection and sticked my palm in every f10 i come across. As it turn out all the f10 do have this aesthetic issue. Didnt think so much about it thereafter cos the car drives fine :)
Actually...detach and slow poke used to meet upevery sat morning...:yikess:
Don't want to touch it liao...later more squeaking and rattle...
Serious bromance.
