F10 535i Front Anti-Roll Bar - GIVEAWAY
Re: F10 535i Front Anti-Roll Bar - GIVEAWAY
wt_know;1001574 said:
front a lot more thicker than rear will cause over/under stear?
I don't feel a significant change in the over/under steer. Perhaps I don't drive fast enough:|
Ai race mai... :D:D
detach8;1001572 said:
I have the m-sport setup so I am not sure what my ARB measurements are. It should be thicker than stock, but not sure how much thicker, or if it's different on the 535i.
From my research, different models use different ARB thickness and the msports model have increased thickness compared with the stock model. So depending on the car model, it may or may not be as thick as the 535i
the M5 ARB is universal application or only for 535 and above? meaning, 520, 523, 528, etc all can install?
I read US forums and most were 535 and 550 who installed it. There were a few 528 and 520 who inquired but never update whether they installed or not....
I read from the US forum that someone from HK who owns a 528 had installed the M5 Front ARB. Even a 520D had also installed the ARB.
It is nvr about straight line. It is how fast u cup corner. I always exit expressway way above legal speed.
If no feel, why change?
Should be able to install. It's just that the diameter is thicker by a few mm.
igo88dev
