F10 Hidden Menus
Centurion9990
I tried and it works. :yummie::yummie::yummie: Got nothing better off to do with your ride? Try it :juggle::juggle::juggle:
Extracted from Bimmerpost:
Speedometer LCD,
1. Hold down the odometer reset button and turn the ignition on by pushing start/stop button.
2. Release the odometer reset button, and you should see a menu of 4 items on the dashboard. From here on, use the odo-reset button to advance to the next entry through a short press, and to select through a long press.
3. Choose the one that says Unlock through the above, which will take you to a passkey screen. Your passkey is the sum of the last 5 digits of your VIN. Increment the two-digit number until you get to it, and with the long press of the odo button, select it.
4. Then you will see a list of the extended menu. Short press to advance to next, Long press to select.
Now for iDrive, there is another set of hidden menu:
• Call up Start menu
• Push controller in up direction for at least 10 s.
• Controller 3 notches to the right
• Controller 3 notches to the left
• Controller 1 notch to the right
• Controller 1 notch to the left
• Press controller once.
• The Service menu is now added as the last submenu to "Settings".
Four selection menus are available in the Service menu of the CIC:
• Navigation
• Telephone and BMW Service
• TV (Not for US)
• Gracenote
[video=youtube;DnUMpkdXuD8]http://www.youtube.com/watch?v=DnUMpkdXuD8[/video]
Re: F10 Hidden Menus
yah lo...free free can go try try.... so what your manufacture mm/yy?? :)
01/11... can buy 4D... $100big $100small
Scroll right down and in Z menu is "Set self-destruct in 30 minutes."
The Idrive Hidden menu also works for E60.....but no idea what is does....
Hi, How to know my VIN no for PI 523i?
Speedometer LCD,
• Navigation
• TV (Not for US)
• Gracenote
Vin code is everywhere in your car. Sticker on many many parts. Easiest is open your bonnet and look for it at the side. Last 7 alpha numeric. E.g DW44677
