glntan;638028 said:Had anybody changed their OEM lights to white LED. If yes, please let me know how you do it for the front reading lights.
skip;640611 said:Yes I have changed all the interior bulbs to white LED. Normal LEDs will work for the F10, don't need to get those error-cancelling type.
There are 2 metal clips in the front (nearer to the windscreen) that hold the console in place, use a trim removal tool or something flat but stiff to push in these 2 clips and the whole console can be popped out easily. Once the console is removed, you will be access all 3 bulbs.
Check this thread for the location of the 2 clips i mentioned above:
DIY: Installing Interior LED Bulbs - BMW 3-Series (E90 E92) Forum - E90Post.com
Although this is for E90 but the location of the clips are the same for the F10. You don't have to remove the headliner, just locate the 2 metal clips and use a flat tool to push them in.
Hope this helps.
Hope this helps.
notti imp;644485 said:Hi Skip,
Will this apply to F01 as well?
I am also looking for the snap in adapter for my iphone4 connection as i have this option (quite a mouthful (extended connection of the mobile phone music player)
Thanks
