F30 mirror problem
Ammar Thabaleh
New Member
I've got a 2015 f30
With the electric tilting mirror
As I've read the passenger mirror is supposed to tilt down as the gear is put in reverse
Mine does not do that regardless on which side the mirror adjuster is put
either the hardware is kaput or your coding could be deactivated.
You need to check on the following codes
1) Mirror tilt on reverse
2) Mirror tilt value on reverse
debet39com
