Faulty DME controller
Stockkid81
Want to know if any bros have a faulty DME controller before and the symptom .
Basically my car experience the following problem almost immediately all at once.
1) tyre pressure sensors showing low air but seems okay as i stop to check.
2) transmission oil overheat error
3) gear like stuck at gear 2 but showing gear 5 on dash board when i try to upshift or downshift cannot be done.
4) RPM varies showing 2k rpm to 7k rpm but i never press the pedal hard.
5) drive train errors appears.
Munich did a diagnostic and told me likely is DME controller problem..
Am driving a F30. at the moment. any brother encounter DME controller issue before can share.
I checked with my sales rep from PML he told me likely is DME controller also...
Item 1 - dsc' job
Items 2 & 3 - egs's job
Item 4 & 5 - Dme's job
So item 4&5 relavnet to Dme.
Sounds more like a transmission flare than a Dme issue ....
