Flushing ATF
Re: Flushing ATF
changing auto transmission fluid gotta change car's oil pan??
what is your ws mechanic telling you?
Re: Flushing ATF
simidaiji;999562 said:
Hi guys,
Wondering if changing ATF require to change the oil pan? Any advise?
it is highly recommended
i think for 320i the filter and pan is 2-in-1 so must change
Re: Flushing ATF
He said the filter is together with the oil pan.
Re: Flushing ATF
simidaiji;999591 said:
I suppose E60 LCI is the same?
My E60 Lci done at R2D only change ATF plus protectant only...
Nothing else Liao...
Re: Flushing ATF
i suppose you are doing this flush to minimize the jerking issues?
Re: Flushing ATF
No jerk...just the 80k km ATF change due...
Re: Flushing ATF
Recommend change the filter, fluid and clean the pan / magnets..........and there's a proper way to refill the fluid. Google for more info.
Re: Flushing ATF
Please watch what you recommend, too much new ATF at one go can also damage the transmission. The seals within the gearbox can pop off when too much new fluid is introduced into an old gearbox.
Are you going to assume full responsibility if you instruct the workshop to drop as much of the old oil as possible? I suppose the usual response would be " how come after you change the gearbox oil my gearbox start to leak?"
What some people can get away with does not mean all can get away... I am not trying to flame anyone or any site. Just trying to make sure the other side of the story is told.
Re: Flushing ATF
Can you explain a bit on how the seals will pop off when the new atf is used? Wondering.
Re: Flushing ATF
Thanks bro. Might need your help, having a tricky situation with the valve cover gaskets now. Towed/drove back to the $^#]%* agent 4 times this week.
Re: Flushing ATF
This is very true... some call this gearbox shock or something to that effect.
Usually, any decent workshop will probably recommend to re-use part of the old ATF (can't recall is it 1/2 or 2/3) with the rest being new ATF to prevent gearbox shock.
Re: Flushing ATF
Looks like many workshops in SG are indecent then. Any rules against blacklisting workshops with f'ed up workmanship that need you to go back 4 times to redo a simple replacement?
Re: Flushing ATF
erm, you might wanna refer this to CASE.
You changed 100% of the ATF?
Re: Flushing ATF
ATF not me, it was another bro. Mine was a simple leak.
Re: Flushing ATF
Yup. Remembered mine had the fluid changed first .......
dagafoscambg
