Forgot to release handbrake when driving for auto transmission F30
Re: Forgot to release handbrake when driving for auto transmission F30
Toh Chen Tat;1044789 said:
I forgot to release the handbrake today and drove for a good 10km then I realized it. What would be the consequences?
Hi. Driving with the hand brake on may "eat" the metal brake disk as well as the braking feets ( two metal parts around the disk). It may cost you good about of money but it your breaking system did not affect so try to be careful next time. Better check the disk by a mechanic
It is possible to run a distance without knowing that yur parking brake is not release. As most of the owner will only pull up afew clicks which is just enough to hold the vehicle during parking. ( I always pull 5-6clicks at N gear)
Rear brake shoe (which is inside the rear wheel hub area) life span will be reduce & ofcos burnt smell will be there. Have a check with yur workshop & see if needed to replaced e brake shoe, any damage on e drum section.
Parking yur vehicle without engaging the hand brake may cause parking sensor, P locking arm to be damage. Hand brake is there for a reason. IMHO :)
** PS, the warming sound is an indication to pre amp the driver. I would have stop & check wat is wrong. Perhaps im just too anal.
Cheers ~~~~~~~~~~~~~~~~~~~
nothing serious will happen to your rear brakes la.... unless u do it daily...
dun scare the noob...
u havent had it as bad as me bro. i had a heated quarrel with my gf once along nshw. at 200kph she pulled my handbrake and refused to let go.. knn after that i smelt a dam bad rubber and saw smoke coming out of the wheels..
did you let her go... after that?
Lucky u are still alive.
Ok lah .... At least haven't advanced to playing with steering wheel or various other sitting positions at 200kph.
I like the style of ur gf. 不管是生或死,都要永远在一起。
what is tat ah hand brake? i search here no have
nothing will happen lah.....
think u din fully engage, cos if so, u will def feel it.
Feel it? If you cant see it then you shudnt be even be legally driving. Uh oh.
eh, meaning, u feel the DRAG.....bah.....u dun try be farni hor.....lol
n u dun be notti hor aunty...wait that sean fella ask u n me go room again...kekkeke
er..this hand brake he referring to sounds like sth that rhymes with trick....
Ooh... ooh. I love guessing games.
Issit stick? No? thick?
Or what about chick? Or geek? Quick?
Smething that rhymes with trick and can be grabbed, and yanked at 200km/h... could it be Meek!?!?
hmmm..maybe her brudder, Mick?
Just check with SA, the handbrake locks the rear wheel brakes, driving with handbrake engage will cause wear and tear of the brake pads and brake rotors to be faster. Prolong deriving with it will damage the wheels if the brake pads gets overheated and stick to the rotors.
Thanks all bros for your advices!!
Erm... seriously... which SA is that?
Come... I give you a picture that tells a thousand words...
The parking brakes are in the rear BUT NOT the same as your rear braking system (calipers + rotors). What you see in the pic is after the BBK and rotors have been removed, exposing the parking brake shoes.
"The parking brake is a drum system that is integrated into the rear brakes. The rear rotor hub flange acts as the drum and the brake shoes are mounted to the backing plate."
As far as I can find, this applies to all 3s including E90s and early F30s ie. 335i. Do correct me if things have changed in the later F30s.
I'm impressed. Bro seanskye not only has the best TWMM piccies, but also has useful BMW ones!
But I prefer the TWMM pics more.... :lol2::lol2:
