Cylinders/Valves = 6/4sds;143915 said:what are the paper specs for your e65?
According to HIOP, it is about 20-30 hp. I am very amazed by this suggested proposed number. that is the reason i went ahead with my ride. lets just hope it is true after post-dyno.sds;143915 said:what are the proposed gains achievable from hiop remap.?
In actual fact, dont have to solder. it optional.sds;143915 said:why was it necessary to solder, components ??
good question. i just do what i was told by J4C amos to run in to allow ECU processor to get use to the new programming then dyno more accurate.sds;143915 said:do we really need to run in the engine with this new map before dyno?
i agree that butt feel not accurate, so if any experts here can confirm dont need run-in like what i was told for 1000km, i will get post-dyno done in no time. will also watch the fuel comsumption too...sds;143915 said:only after dyno will you know value for money or not...butt feel not accurate one. eagerly await your dyno charts..thanks
kopi_o;144873 said:The results sound about right, if slightly low, for the 3.0. The engine is already quite highly tuned. The improvements for the 523i is much better since the 2.5 is a detuned version of that found in the 525i. Even then Hiop still cannot get the same hp as the 525i.
pingman;144887 said:the total hp gain is pathetic at 254hp, this number is even lesser than the stock 258hp on paper and only 5 hp from pre-dyno. even though the butt feeling is good, and is probably due to 'sprint booster' and '10Hm' more torque, i m suspecting they are not doing it right.
the gain should be same or if not 50% of what was achieved on the 523i case. in my case, its 5 hp gain only. is that 'sound right'?
any more expert opinion please.
TheNew7;144902 said:But please confirm that your tests were done at the rear wheel rather than at the engine......
louis;144908 said:i believe all the local dynos are at the wheels... crank figures are obtained by multiplying the rear wheel figures by a certain factor to correct for drivetrain losses.
rex7_vtec;144915 said:your predyno of 249bhp is at the crank right?
rex7_vtec;144915 said:From say 2000rpm to 5000rpm the difference between power curve is approximately 30bhp. Torque has also been pushed down towards the lower revs and has been slightly increased as well.
While I'm not indicating that this is definitely your case but it does show that your torque and bhp increases the most during the range of 2250rpm to about 4750rpm. Percentile increase that is.
pingman;144979 said:the dyno is at the rear wheel. they took out the 2 rear wheels and stick 2 machine into where the wheels are supposed to be.
so do u mean that is the right way to read the graph. i was told by the dyno guy that i gain only 249 to 254 bhp but gain on the torque about 20Nm on ave. insist that i get the tuner to explain more.
i m also not sure if this is my case - that is why i m looking for opinion on how to read this dyno graph?
changster77;145049 said:On engine software alone, they onli safely extracted 6 bhp from the 328
Take note that with software, high flow intake, throttle body and exhaust, a world reknown tuner like dinan could only squeeze 14 bhp out of the old E46 330.
