Front and rear camera help
xcore
Hey guys, I went to a shop looking to install front and rear camera and was told that if I did not use BMW Ace camera there will be a battery error and ECU fault code. And the only solution to put any other type of cameras would be to have an external battery. Can anyone shed some light on this? I'm sure not everyone driving a BMW is using the manufacturer's Ace camera right?
Yup a camera without external battery will eventually have a BMW warning about increased battery drain. However this only happens if your camera is wired to be a 24hr continuous recording whilst car is NOT running.
To avoid this either get a external battery or wire it up as working only when the engine is running. Alternately increase the minimum voltage before camera is automatically shutdown to prevent this msg. Carousel has plenty of external batteries for sale just search iroad or cellink or just external car camera battery.
choangonline
