Front lower control arm
Re: Front lower control arm
Most stockist will have it I will normally go here because its close to my place. Have a proper workshop check it out 1st before replacing tho saves time and $$ as sometimes just the bushings can be replaced instead of the whole arm.
Stockist
Integrated Global Network Enterprise.
9 Kakit Bukit Road 1 #01-11 Eunos Technolink Singapore 415938
6348 3083
Workshop
2277
DavidChen;1083699 said:
Hi bro,
Recently I have the front control arm wearing out inform by pml, but I think their price is unreasonable. Lucky I saw your post. Can u share with me where u did the repair? Can I have their address and contact? Thanks
Hi guys,
For the wishbones normally the bushings or ball joint will wear after time, here are some pictures you can refer to.
View attachment 63145View attachment 63146View attachment 63147View attachment 63148
Do drop us a pm with your number plate if you want a quote.
Eng Soon Auto
hi.. I believe my lower control arm need replacement. may I know e cost to replace both front and any workshop recommendation? thanks a million
brought 2 lower arms n 2 upper arms brushing then went to a reliable workshop fixed it all up total cost at $380
this include wheel alignment
Bro, my f10 when I just stopped and engage reverse gear and reversed halfway into the carpark, there's a 'tock' sound. But not for going forward.Is it also the control arm? I sent in to pml for 3 days and they say they tighten the screw and found nothing is wrong but the sound is still there. Car still under warranty but only till end of oct
Eng Soon Auto;1095637 said:
Hi guys,
Eng Soon Auto
Hi, would appreciate if you could pm me for the price of the Lower control arm bushing and ball joint for bmw 318i Lci.
Thank you in advance.
Hi, want to know when it is mentioned need to change the front lower control arm, does it refer to the control arm only (right side)? or along with the track arm (left) too?
99okmeme
